Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Should have left well enough alone!
Fresh motor (1200 miles) and the car was running GREAT with the stock set-up and 87 ECM and MAF.
Got the bugs worked out and changed over last weekend to TA33, red stripes with TT Alky. Found out after 3 miles that the TA33 blew LOTS of oil.
So, I pulled it out and re-installed the stock turbo, left the TT, red stripes and fresh oil.
Now it won’t run on all 6 (#6 is wet, others are sooted)
New plugs (tight 0.035).
Changed plug wire on #6
Changed coil pack and module with a spare.
Compression is at 120 (Same as cylinder nr 3)
FP stays at 42 for a while, so no leakage.
Injectors were bench tested before install.
ECM connectors verified and checked.
Chip verified for install (4 times!)
I am running out of ideas.
