dr_frankenstein
Mad Scientist
- Mar 17, 2008
Adam is correct! there are much cheaper ways then the aeromotive stuff!
SignUp Now!Yes thanks for posting the cam card, I actually like the tighter LSA on that cam I believe it would be good with boost for being an NA cam.
The fuel system I ran on my blowthru wasn't too expensive and worked great and It supported nearly 400whp and 600wftlbs on N20, 300whp and 450wftlbs just boost.
I used an inline EFI booster pump (MSD 43gph) and a Mallory 4309 rising rate fuel pressure regulator, built a return style fuel system with the stock supply as return then connected it all with push lock hose. Probably a little over $300 if everything was new but you could sub some of those parts for cheaper stuff or get used.
I disagree on the cam. There's going to be a lot more overlap than needed with that cam and it will have a high narrow power band. The converter will need to to stall to at least 3800@0 to not be a pooch and ideally need even more. I would order up a specific cam. Preferably a fast ramp roller. You can cut out a bunch of overlap and pick up a lot of cylinder pressure from 5000rpm down to 1800. The valve opening/closing events with that cam installed straight up are similar to what would be run in an engine where the car was projected to run 145-150mph in the quarter.
eastwoodad said:The converter already stalls around 3400...I know the cam isnt ideal, really just trying to work with what I have already and select a turbo that best fits...knowing it wont be ideal.
That cam really throws a curveball though. It would need a lot of valve spring and 3400 isnt enough imo. I wouldn't want the engine below 5800 under power and would probably shift around 6600 with something like that if it was a solid roller. I have a stock replacement cam for an 84-85 that's been sitting in my inventory for 15 years. I give it to you. Just pay the postage. I don't have a card for it but throwing the degree wheel on it will give you enough info on it.
eastwoodad said:I actually have a stock 84/85 cam from when the motor was yanked...thanks for the offer though! I initially built the engine as N/A, hence the cam choice...just seeing if I could make it work. I do routinely shift at 6200-6300 with no sign of valve float. It has the heavy duty single springs (105 seat pressure I believe). Before I really turn it up, I would like to get some nice lightweight roller rockers and ditch the adjustable pushrods. I havent searched yet, but assume somebody has a good beehive spring available for this application.
