Notch top of cylinder bore
Walt03
Does anyone have a template that I can use to notch the top of the cylinder bores and depth from top of block to help flow to the Intake and exhaust valves.
I saw that someone had this to offer but I don't remember where I saw it.
Any guidance would be appreciated.
Thx,
Walt
Turbodr1 is the guy your talking about. I saw the same thread, but I forget where. Maybe in the Fab section.
The factory head gasket will allow you to scribe a line......however, if you are using a differnet head gasket, you MUST use it to detirmine the cut. About .050" above the top ring is your depth.
Great illustration tyrbo1dr.
That is just what I needed, now to figure the cc's in the overall head cc will
be the trick.
Can't be more than 2-3 cc's for this operation wouldn't you say?
Thanks for your help.
Walt
