Steve Wood
- Jul 18, 2001
Autolite 23 measures 4.17 k ohms
SignUp Now!That happens alot with the Magnacores....... Another big difference is how well they reduce electrical interference.The real difference in spark plug wires is in the quality of manufacturing....it's an aggravation to grab the boot and leave the connector on the plug.
Originally posted by Rogue Leader
Hmm well now I am much more educated on Spark Plug wires... Im still going to install the MSD wires, But I think I'll save the Magnecors for the future, always good to have a spare set... Another thing with them is the boots are a bit lose, that was another reason I was changing them... they have been pulled off a few times and really didnt attach very well any longer.
Another thing with the magnecores... they say Magnecor KV85 on the wire but the angle boots have Accel 8.8 stamped into them??? weird huh?
I am just removing a set of Magnecores from my TTA... supposedly really good wires, they are approximately 2 years old and only have about 4000 miles on them. They are being replaced with a set of MSD wires (btw for the MSD's to fit you have to cut the straight ends off two of em and replace with angle boots for the #2 and 4 cylinders by the downpipe, no big deal), MSD only makes a GN set not a TTA set thats why.
Testing the wires I see the following:
MSD Wires 55-65 Ohms Resistance
Magnecore Wires 350 Ohms Resistance![]()
Anyone else have any wire experiences to share????
I came across this above quote by Rogue Leader while searching through the archives on plug wires & although I posted my own experience in another thread that I started, thought that I'd repost it here...
I just tested my factory GM plug wires & the meter I used is a Actron CP7672, digital meter(19.95 @Pep Boy's). The ohm settings I could choose from were 200, 2000, 20k, 200k & 2000k. I tried the 200 & 2000 settings first & got no reading, so went to the 20k setting & got these #'s...
All 6 wires tested between 4.30 & 6.80 which I've been told by salvagev6 is between 4300 & 6800 ohms on that 20k setting. Not sure what to make of those #'s.....are these wires up to par or should I be looking to buy new ones?
Thanks, The Darkside![]()
