Im going to be replacing my timing chain soon. While I have the front cover off, should I put in an oil booster plate? Doesn't that increase the oil pressure? Is it expensive? Is it a hastle to replace? Where can I get one?
My car has 112k on it and the oil pressure is getting kind of low.
60psi at cold idle
15psi at hot idle (my car doesnt run any cooler than 190 deg. Im replacing the WP and thermistat when i replace the timing chain.)
thanks
BOOSTD
60psi at cold idle
thanks
BOOSTD
