First off this is my first car with a turbo on it.
I was reading my Chilton's manual over the turbo 3.8. It was telling me anytime you change the oil you're supposed to "unplug the pink wire from the distributor and crank the engine several times until the oil light goes out".
This is obviously for engines equipped with an actual rotary distributor. I know on rotary distributor cars the pink wire is the 12 + source to the coil.
Now what about the SFI engines? I am assuming you will also need to disconnect the ignition wire and crank the engine a few times to get the flow of oil into the turbo before you actually let the engine fire and run?
If so where do you typically unplug the ignition at? Because I can't seem to locate the power + source for the coil packs.
Thanks.
Thanks.
