J Justin85 Member Joined May 23, 2012 Oct 21, 2014 #1 Should the Oil Choke light come on once you turn the key before you turn over the motor?
salvageV6 Daily Driver Joined May 25, 2001 Oct 21, 2014 #2 Yes with no oil pressure the light will be ON, with the key in RUN, START, and BULB TEST.
salvageV6 Daily Driver Joined May 25, 2001 Oct 22, 2014 #3 Well maybe not, I tried mine this morning and it didn't come on.... Now I have to troubleshoot my wiring/connector or the factory service manual.
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Oct 22, 2014 #4 if you removed the stock oil sender switch at the pass side by the timing cover and replaced for an oil gauge sender or line then it wont light Last edited: Oct 22, 2014
salvageV6 Daily Driver Joined May 25, 2001 Oct 22, 2014 #5 Got to work, went outside at break time and voila, light comes ON, key ON car OFF. Must be a bit intermittent when cold. The service manual is right.
