Oil Cooler Fitting - Radiator Side
bigballsbilly
I believe I read on another thread that 3/4" male inverted flare is needed to go into the radiator for the oil cooler line. Problem is I can't find it anywhere. Where did you guys find this fitting?
That's got a barbed end, your going to use a hose clamp? I was hoping to convert it into NPT so I could convert that into -AN
Nope that one doesn't go up to 3/4.
Actually it is 1/2" inverted flare as discussed before. Look at the part number closely. Then go back and look at the part number for the one with the thread 3/4-18 listed for 1/2" inverted flare fittings. This is why I mentioned call and confirm...
