Well 5 months later...I finally got my engine back from the engine builder. He did have a concern about the amount of oil flowing into the front cover. He primed the oil pump and looking through the fuel pump opening he showed me the stream of oil. Oil pressure was 70 psi and considering the oil had already flown through the cam - it had already did it's job. So he thought it was likely just the way it was, but I thought I should double check. Is this normal? It was pouring in there pretty good
