stickybones
What?
- Dec 27, 2001
I know oil leaks are a common problem, but how common is it for the oil pan gasket to be the culprit?
I've already replaced mine twice and the damn thing still leaks. I've looked closely and I'm fairly confident that the leak isn't coming from other common sources such as the front cover, turbo oil return line, rear main, valve covers, intake seals, oil cooler adapter or hoses, etc. The symptoms are a wet torque converter cover, wet oil pan bolt heads, wet frame cradle (where it runs east-west under the motor) and oil dripping off the trans cooler lines right where they parallel the oil pan before they turn up by the crossover pipe.
I'll replace the pan gasket again if that's what the problem is, but damn, how hard is it to get this thing right and not have it leak?
I've read about making sure the block surface is crystal clean and bone dry before reinstalling. I've used the thick cork gasket both times. Used 3M adhesive to put the gasket to the pan and then intalled dry against the block. Maybe next time I'll try some silicone or something on the gasket top between the block and gasket. I don't know.
Damn it. I hate oil leaks.
By the way, I use dino oil...Kendall GT-1 10W-30.
Mike
Mike
