turbobooster
- Nov 12, 2002
im replacing oil pan gasket i have everything apart n cleaned up ready to go back on but do i need to use a sealant inbetween the gasket ? or do i just install as is nothing else?
thats what i have the 20 bolt rubber gasket wat kinda of spray tack u talking about?
thanx guys the brake fluid will degrease the block right?
Hi,
I would use a thick cork gasket,and Permatex Right Stuff on the block side lightly.I have zero faith in the silicone gaskets,having had a leak problem with them. Since my overhaul in '08,no leakage at all with the cork. I bought mine from Kirban,used to be referred to as the Duttweiler cork gasket,if I remember right.Good luck with your reseal.
