ShawnR
Fixer of crap..
- Jan 24, 2011
A few mods to the oil pan.
1: Closed off the original drain plug that stuck up into the pan preventing the stuff in the bottom from draining out. New one has the threaded bung on the outside so it is flush with the bottom inside the pan.
2: Turbo drain tube attached copying Earl Brown's design where it is always sloping down into the pan. Original attempt was at the rear of the pan, but there wasn't room for the elbow between starter and pan. Cuss, cut, grind, weld.....and all fixed.
The baffle was added as well using a template found online.
