Oil Pressure Sender
DCVING 6
The "T" fitting I bought to add my Autometer sender sticks out too far and hits the block, so I can't get it to thread in. Would I be able to use these two 90's as shown to shim it out a little bit?
Here's how mine is set up.
I am using a PTE turbo saver so I really don't need the 1/8" port off the side of the stock block. Guess I could just get a plug for that one...
It's not a 1/8" NPT port, it's an inverted flare thread. You would need to fabricate a tube and cap it off. Otherwise, you can drill it out and tap a 1/4" NPT thread, then use a pipe plug.
