Oil pump cover
GNational86
Anyone have a part # for the oil pump cover. I dont need the pump gears.Gm is discontinued. Any aftermarkets make them? TIA
If it's not lunched too bad you can just resurface it. Tape a pice of fine sandpaper to a thick piece of glass (my dining room tabe worked nicely). Wet it with WD-40 and sand the cover in figure 8 patterns taking care to apply even light pressure so you don't sand the leading edges in the direction you are moving. I've done this numerous times on the same cover and it always puts a nice fresh surface on it.
sander
I have a 6X48 belt sander in my woodworking shop. About 20 second with a new 120 grit belt and presto perfectly flat and clean surface.
