Alright so I bought an engine off a guy this fall (its actually a 350 Buick V8 but from what I understand the oil pumps between the V6 and 350 are pretty much identical) it had sat outside in the rain waiting for me to come pick it up so when I drained the oil I got a nice chocolate milkshake out of the thing. I then decided to just re-gasket the entire top end, I got it apart, looked really clean with no signs of damage or rust at all, so I put 'er back together and dropped it in my Regal, Just got around to finally firing it this weekend, fired right to life but I noticed my oil pressure gauge was bottomed, quick inspection revealed the line was empty, I pulled the filter and it was bone dry as if it just came out of the box. So obviously the oil pump isn't pumping (oddly the fuel pump doesn't move fluid either but I'm not real concerned about that, just an excuse to put an electric on it). I will get a priming tool in it probably tomorrow to confirm or not but if the pump is bad can I just rebuild it or do I need to get a whole new unit? What may have caused it to fail like this (the motor supposedly ran good when he pulled it, it fired right up when I sprayed ether in it and it doesn't smoke so I don't have any reason to doubt the guy)? And what is this Vaseline trick I've read about?
