SignUp Now!Oil pressure switch??
I just noticed the security light is flashing when I get in the car?
Maybe this is my problem. I have never had a GN with a factory security system.
How do I shut this off?
Den
Over and over it would start right up and then stall.
After this I replaced the cam sensor cap are verified 25 deg ATC. This is the same time I hooked up the battery charger backwards.
After this the car would not fire at all. I pulled a plug wire and put a spare plug in and turned the car over, did not see any spark.
1 car does have a scan master and I have turbo link hooked up as well. No codes on turbo link. TPS show close to correct settings and responds to throttle movement
2. See above
3 I checked for fuel pressure with key on, would not pressure up antil you cranked it, once running it had good pressure. My car is the past seemed to have fuel pressure when key is on? I even tried hot wiring the wire to the pump (the wire on the drivers side behind the AC), made no differnce car still stalled. At this point if dissreguarded FP as the problem.
4 yes
Is the cam sensor reconnected? The computer needs the cam sensor signal to start firing the injectors.I have tried up plugging the cam sensor to see if it will start in limp mode.
If you hook up the charger backwards you are basically forward biasing the output diodes from the charger thus putting a short across the battery. The battery can damage the charger. You won't reverse the bus a bit.
There is most likely some sort of thermal fuse on the output of the charger that will open if this event happens. Now if the battery is 100% dead with no charge you can fry the battery and reverse the bus.
I'LL be in alaska the second week of June if all goes well. If you dont have it figured out by then, i'll swing byput the beer outside to stay cool
sounds like the cam sensor is off. Have somebody crank the car while you turn the sensor one way or the other until it fires. Works for me. Sounds like everything else is ok.
Well I would trust I can figure it out by then. But do drop by to visit if your in the Fairbanks area. We can go for a roll in one of the cars.
We will need to put the beer in the fridge by then, it will be 90 degrees out then and 24 hr sunlight.
Den
You wont believe this...
Aminga: your post nailed it on the on the non running issue, it was the MAF, unhooked it and it ran. Put a spare MAF on and now she will run.
Dennis
