OK wiring experts...do I have a bad fuse box wire?
d0n_3d
Boost is good.
Here's the problem. I'm trying to get my lights to work on my boost gauge on the pillar and my hood mounted fuel pressure gauge. They all of a sudden stopped working when I put in the GNX dash. All 6 gauges on the dash work flawlessly and the lights come on when they are supposed to.
I checked the fuse box and checked my fuses. They all looked good to me. So I checked the grounds on both gauges. They are fine. I checked the power wires going into the IGN fuse slots. Well when I plug those wires into the BAT slot, the lights work. But when I put them in the IGN slot with the key on...they don't work. Should I check my wires by the starter to make sure one of those lines isn't bad? Aren't one of those lines for the fuse box?
My last annoying problem I have is...whenever I turn my parking lights on or my regular lights on...I hear a constant beeping (like the fasten seatbelt beep). But I have my belt fastened and it still continually beeps. How do I stop the beep!
hmmm well not sure on the issue with the lights on the gauges. Possible fuseable link down by the starter took a hit and died.
As far as the seatbelt beeping it's the chime box under the dash is bad. Search around on the boards I know I had a few posts on it. It's about the size of a pack of smokes just to the left of the radio (looking at the dash) somewhere behind about or above where the right hand mirror adjust would be. It's a little tricky getting it out of there. My car would chime and the seat belt light would come on when I hit bumps. And out of no where. I replaced that chime box and it's been perfect. Good luck let us know how you make out!
IGN 3 is on the A/C fuse.
IGN 1 are all on the STBLT fuse/ACC fuse which most likely is blown due to the nature of the other problem.
