Earl, when i jump it using the prime wire, the pump runs. If i turn the key forward without using the prime wire,the pump does not prime. Also i noticed that when i use the prime wire, the racetronix relay for the hotwire kit has to be moved around or twisted a little for the pump to work. In other words, there seems to be a connection problem inside the relay. If i have my wife move the key forward while i twist the relay around, the pump does not turn on. Again, this is done with the prime wire not connected. If i use the prime wire and twist the relay around, the pump turns on.
