BEATAV8
The Engine Whisperer
- Feb 14, 2002
My new motor has some coolant seepage dripping from 3 of the outside head studs, and maybe from some of the studs under the valve cover too (don't know yet). I used permatex teflon thread sealant but I must've not used enough to do the job. Guess I really should've layed it on heavy.
Anyways, what do you guys think I should do to fix it?
Pull the heads? (new gaskets.... bummer....)
Pull the studs one at a time and reseal / retorque them individually? (all of them, ofcourse) In sequence.
Try GM sealant tabs and see if that does the trick? (over optimistic?)
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
