I am getting some water out of one of my head studs. It is the stud on the passenger's side all the way in the back on the bottom (I dont have the heat/ac box in so its very easy to get to). It is dripping out of the stud and onto the floor. I pulled the #6 plug and cranked the motor over to see if the cylinder had any water in it but thankfully none came out.
Sooo.. can I pull the one stud and reseal it? I used ARP's thread sealer and have had great luck with it in the past (zero leaks and had the heads off at least 6-7 times). The motor has about 500 miles on it since the heads were put back on. I use cometic gaskets and put a brand new set of head studs on torqued to 85 with ARP moly on the washer/nut. They were torqued on the stand ONLY and have NOT been loosened and re-torqued. What process should I follow to fix this? Loosen all head studs, pull the one, relseal it and put it back in?
This sucks, I thought I was ready to go do wheelies on central!
ps can water even get into the #6 cylinder if the stud is leaking? I didnt think so but want to confirm.
