opinions on TT wideband correction please
I wish that could be put on the powerlogger graph screen. It would be useless most of the time (only during correction) but being able to graph it would give you a better idea of "average"
good info. so when you first get the chip the correction feature is turned off correct? then you will turn it on and it should start correcting"?
You look at your blms at wot ... the relative number from 128 will be the fueling correction (ie. 125 would be taking fuel out and 131 would be adding fuel).
So do you mean the yellow highlighed blm cell?
A few posts up eric said they were set to 10.8 so it's on.
didnt see where he said that sorry. i just know when we switched to 60's and the new 6.0 chip we did a test run and it was getting richer and richer the londer we stayed into it. didnt see it correcting but will have to look at the logs again. only made one pull didnt have time to make more then that
