OHC engines are a waste of time.
\If you have as stated goal of making the largest engine with the most moving parts then OHC is the way to go.
Otherwise, it's blatantly obvious these days that the pushrod engine (i.e. the LSX) is vastly superior.
Show me one ohc engine that can match the LSX in performance potential, price, reliability, efficiency, and packaging.
For some reason people seem to think that added complexity is synonymous with technological progress.
I don't understand that.
If you built an engine with 3 moving parts and it had the same performance and efficiency numbers as a BMW dohc engine you would still have people raising their nose and saying that the BMW engine was far superior.
Also, what does hp per liter matter? If I built an 8 liter engine that put out the same power as a 4.6, got the same fuel mileage, had the same reliability... what difference does it make? What does having less displacement internally give you if it doesn't give you better efficiency? Seems almost like kind of a dogmatic belief that HP per liter actually accounts for something in the space time continuum
