What the fastest with 67 so far?
insane6
Senior Member
87 GN
TE-67 ,60#inj, thunderfab I\C 21 row
212-212 comp
6.75 @ 24psi @100 MPH (1/8 mile)
93 pump gas \alky
Sal Lubrano
Senior Member
PT-67 (.63A/R, P-trim) 10" WestCoast converter 3800 rpm stall,
Eastern FM, 3.5" Maf, Translator plus, 3" THDP, Hooker Cat back, 3" Cat,
Mototron 60/65 lb/hr injectors, comp cam 206/206, Adj fuel reg, Extender Extreme chip,
SMC Alky, Holley 255 LPH fuel pump hot wired, KN air filter, RJC power plate, Air bags,
UMI Lower control arms, Metco driveshaft loop, Eaton Posi, Poston's crossover pipe,
Dual 11" Spal fans, Arizon GN Radiator, Directscan and Scanmaster II
paul vilser
Senior Member
I've had the PT67 for 3 years, since they first came out. It's awesome on the street and strip. Little turbo lag on the street and at the track, I ran a 10:78 @126
WE4-Original owner- 10.78 @ 21PSI @126 street car- GN1 heads & intake, Garrett GT67 turbo, roller cam, JE pistons, PTE front mount, Double Pumper,complete stainless exhaust. Backup car: A yellow 70 GSX, Stage 1, 4 speed car.
breiter
Coolboost
67 vs 63
87 GN, TE67, Champion irons w/ SCE Titan head gaskets, Champion intake, Kenne Bell 208 cam, TRW pistons, billet caps, Eastern FMI, 62mm TB, custom plenum, 60lb Mototrons, RJC Boost Controller, 3500 Pat's Converter, Art Carr 2004R, Setrab cooler, Performance Instruments Dash, 1" drop springs, Tubular A Arms, S-10 rear brakes, Blazer front disc's, Gen2, LS1 Maf, Ext G chip, LC-1, Big Mouth Cold kit, 3.5 MAF pipe, Angle Boss, 255/50/16 BFG drag radials. More to come...
d0n_3d
What's in YOUR wallet!?
__________________
-Don
87 GN - 11.12 @ 119 mph, best 60 ft of 1.51 (done on previous PT61 turbo @ 25 psi) 10's on the horizon, no new times with new combo yet
PT67 P-trim dual BB w/ PS cover, high-z 65's, Translator Pro w/ LC1 AFR correction & Extender Pro chip, 9" Art Carr 3200 n-l stall, Vince Janis built 200-4R, PTE FMIC, GN1's unported, ported stock intake, T&D 1.55 ratio roller rockers, Comp 212/212 flat tappet cam, STOCK untouched bottom end 115k miles, GNX dash, daily driven street car, fully optioned, full weight car, cold a/c
TURBOBUICKS.COM
Yullose
Certified gun nut
'87 GN...Best ET: 10.95@122...1.54 60ft...(25psi/C16) NO Nitrous...NO Alky...On a STOCK UNOPENED LONGBLOCK...PT6776e...PTE FMIC...MSD50's...TT Race chip...Big Mouth cold air kit...LS1 MAF...Trans+...TH400w/transbrake...10"/3000converter...100HP NOS kit
J Banning
Lettin' loose the cougar!
.Mods: PT67, .040 over Hypers, N/A crank, stock valved iron heads, 218/222 cam, Powerstroke IC, 83# injectors, MaxEffort-R, Art Carr 9"
PaCemkr86
WFO Racing
Almost there.. 11.20 @ 17 degress of timming and 18 lbs of boost
10 psi launch. with a single nozzle alky contol kit.
231 cid
turbo charged V6
fully loaded
custom front mount, sheet metal intake, 3.42 gears w/ posi
PT67 turbo, alky injection, roller cam, ported heads and intake and a bunch more other stuff that my husband has installed on it.
paul vilser
Senior Member
10:78 @ 126
10.78 @ nearly 126 mph through closed exhaust on MT DOT tires @ 21 lbs boost on 110 octane gas. The fully optioned car weighs nearly 3700 lbs with me in it. No line lock - I launch the car by braketorqueing to about 2 -3 lbs boost.
Motor built in 2003 by Pete Barton of ANS. Stock 109 block, bored 10 over. 4 steel main caps and ARP fastners. GN1 heads & intake, Garrett GT67 turbo, 62mm throttle body with PTE upper plenum and RJC powerplate, Buickgn.com cold air kit, Comp 210-210 roller cam, JE pistons, PTE front mount, ATR Double Pumper, 57 lb Seimens high impedence injectors with stock computer, Turbotweak chip, 3" TH downpipe, ATR 2 1/2" stainless exhaust.
Trans by Jimmy's Transmissions, 3400 stall Precision 9" lockup convertor. Aluminum driveshaft, Moser axles, stock rear end. ATR big rear sway bar - no front sway bar. H&R upper & lower control arms, 1 air bag and a pinion snubber.
