J-B Racing
Forced Induction
- Sep 16, 2003
I have no 02 readings again...Need Help F.A.S.T.
Joe
Joe
SignUp Now!Cal is @ BPG.
Whats it doing, please give details l?
When you re-installed the program you will have to select the com port it uses for communication again. Are you using the fast serial adapter, windows XP?
Joe you can;t use the Bosch sensor on the classic fast. You need a spare NTK sensor to try. If you download this program and your laptop is connected to the internet and the fast with the key on. I can go into your computer and try and get it working. I just need your ID number and password once you run the program it will ask for it.
TeamViewer Version 6
When you say the WBO2 "doesn't work" do you mean it's not displaying an A/F ratio or that it isn't showing any UEGO voltages?
