Paintjob is almost complete... Picts within
Pablo
now for the excuses
Yes I'm aware of the dent in the hood. There are quite a few more that decided to make cameo appearances once the shiney stuff was on the car. People also seem to think that body work is the same as paint because everyone I have look at the car to critique it immediately points out the dents. I always have to say "look at the PAINT not the dents".
There is dust all over the car.
I still need to align the trunk lid.
I have not done any final wetsanding or buffing whatsoever. I did however test a small area with my buffer and some 3m fine cut rubbing compound and the results were amazing.
I obviously still have to do the bumpers, grille, headerpanel, and that little trim piece from the trunk to the rear window.
I have some paint that got onto the fenderwell that i need to clean up. I also need to clean up and polish my weld draglites (only the fronts are shown) and put those back on.
Other than that (atleast thats all I can remember) I'm done.
I learned a TON during this process. I can only liken it to bootcamp (USMC), It seemed like it took forever (it did), took way more effort than I thought it would, really hated it at the time, made mistakes, would probably not do the whole thing over again. I did however learn some valuable lifelong lessons that I'll never forget.
The nice thing about the paint is that I can now repair and retouch it whenever I want since I have mostly conquered the technique.
What do you guys think?
Looks like it turned out good man, especially for a first timer? Found out fast why we charge you so much to paint a car though didn't you hahahahaha. Painting one right is a LOT of work, not just oh well all you do is sand it and slap some bondo on spots and paint it. Would be nice if it was that easy in the real world! You think you had some dents jump out on you on white, try doing a black one!!!!! You will find out fast if you have conquered it or not hahaha. Good job man and welcome to knowing the real deal on painting a car now! Daniel Ray
Dreamscape Kustom paint
Fitzgerald Georgia
Nice start. Painting is alot harder than it looks. Prep work is really the key and it's not easy to get everything just right.
What do you guys think?[/QUOTE]
That's why nice bodywork is so expensive.:smile:
Be proud! It's a big accomplishment. Post more pics after it's sanded and buffed!
But then get ready for the next one, cus for sure people will be asking you to paint their rusty piles and make them look beautiful for peanuts. ;)
Did you paint it in your own garage? It's damn near impossible to do a garage style paint job and not get dust. I've painted two cars in my garage and the 2nd one I completely plastic'd everything off (ceiling too) and sealed up two fans to the plastic and it did a damn good job side drafting the overspray. I also leave my compressor outside, not in the garage when I paint.
I'm going back and forth on whether I am going to paint my T or not. Right now I am bringing it up to the point where all it will need is masked off and the base and clear shot and I'm going to ask some paint shops what they would charge, if they say over $1,000 dollars I am probably going to do it myself.
Your paint job looks good though, better than my first car paintjob. I didn't shake my gun enough in between passes and my metallic streaked on me on the hood and trunk. That's the bugger about paint, hours and hours of perfection can be ruined in one split second.
Looks pretty good for a newbie. I love the white on the g-body!
Great job! My hat's off to you for having the b@#$% to tackle what most of us would never dream of doing. Car looks great, and you have the satisfaction of knowing that you did it all yourself! :)
For your paint job it looks good ,you should be proud it's not easy painting a car ,lots of time in body and prep work but you did it congrats to ya for doing it yourself..:biggrin:
I'm working on it. I'm still assembling the interior and whatnot.
Thanks for all the kind words guys. I just picked up some buffing pads and hopefully will get started polishing soon. I still need to throw paint on the bumpers though and headerpanel. Hopefully I'll be doing that today once I'm done putting the interior back together.
Any polishing tips? I got a red heavy cutting pad, a medium (yellow, though i know diff. manufacturers use different colors) pad, and a black finishing pad. Any polishing tips? I'm wondering if I should use the cutting pad. I have some light orange peel in places I'm hoping this will take care of.
When did you finish it? I'd let that bad boy sit out in the sun for a few days before I even thought about buffing it. My tip is to put tape on the edges as any home paint job isn't going to cure as fast as a baked on body shops and to use ultra ultra light pressure and get no where near any angled ridge at all or you'll cut through it faster than you would ever imagine.
the car was originally silver, i just put on the brightest white i could find to make things easy :) I dont know the original silver paint code
Is that artic white? Wow, that looks wicked! There is so much of difference in how the car looks when you compare it to the duller white colors often seen. That color is super bright. That looks Hot!
Thank you for the kind words, they really keep me motivated. Its so much work and frustration sometimes that I just want to torch the car but these posts help me continue.
The color is actually called blu-glo white, I didn't understand the blue part till my buddy who paints airplanes told me that when he wants to make a white REALLY bright, they add a touch of blue to it. The blue is not visible but for some reason it makes the white look even brighter than it would have. I don't understand how it works but apparently it does.
I'm slowly finishing the car. The interior is completely installed, I polished the door steps (those aluminum things that say body by fisher) took care of the overspray, and managed to paint all those other parts you don't see on the car.
I managed to royally screw up the rear bumper and header panel though so I'm waiting for them to dry so I can sand them and re-shoot :( two steps forward, one step back.
Apparently paint manufacturers aren't kidding about either re coating immediately, or much later, but not in between. I had to find out why and was rewarded with what looks like a dry lake bed paint finish on the rear bumper and header panel :mad:
TNX, I actually managed to finish painting the car a few weeks ago. Ive mostly been dilly dallying in putting the final touches on it and posting it up. The garage has been pretty hot for the past few weeks and the paint has stopped "smelling" up the garage so I think its ready for some polish when I get to that stage.
Yes I did paint it in my garage and I didn't build much of a paint booth so I do have dust here and there. I did make an effort to really clean out the garage, with water, and seal off any potential inlets of dust. That said, it's no show car but I think it looks pretty good and thats mostly what matters I guess. I'm used to what it used to look like so this is a 1000% improvement.
Right now I'd say its a good 5 foot paint job in good light conditions. In direct sunlight though its so unbelievably blinding white that you cant see anything besides your retinas burning in your skull :cool: So that helps
You can see what I started with in this thread: http://www.turbobuick.com/forums/sh...-t-type-needs-help-im-ready-tackle-enemy.html
and this is what it looked like when I first got it almost 4 years ago
