GlockandRoll
- Nov 13, 2009
Its still a triangulated 4 link so it still laterally locates the rear. The purpose of a watts link is to keep the rear end from moving side to side. The upper links of the 4 link, wether it is a swivel link or not, also prevents the side to side movement of the rear. Having both would cause conflicting roll centers and the car will try to rotate around two different points. This creates a tremendous amount of stress on all of the suspension components, and causes the car to handle poorly.
The swivel links from DSE are great pieces. They allow the rear to move smoothly through suspension travel and roll. They do their best to limit bind which is one downfall of ALL triangulated four links.
The only time a watts link or Panhard bar is needed is on a rear with parallel control arms like a parallel four link, torque arm, or a three link because their control arms only distribute forces towards the front and back of the car.
SW.
thanks, good info... this is what I am learning as well.
