Parting out 85 GN Motor
imjoesnuffy
I just break stuff!
Hot Air block, 85 20 Bolt oil pan
8445 Heads stock
Stock connecting rods with pistons
Intake
Stock injectors 117K
Fuel rail
Stock 85 MAF
85 Coil and ignition
85 ECM with chip
All pulleys
AC Components
Ceramic coated Headers, up pipe, beginning of a downpipe, crossover, never been used. Not sure of the manufacturer, $500 Pics here:
http://img.photobucket.com/albums/v214/robpas/GN.jpg
Stock Throttle bod
I also have everything needed to do the 87 ignition conversion.
87 Coil
Adaptor plate
CCCI Harness
https://www.casperselectronics.com/...e=8485GrandNatl
https://www.casperselectronics.com/...5GN_Performance
https://www.casperselectronics.com/...Code=8687GN_OEM
All ignition stuff uninstalled, brand new. Make an offer.
Selling this motor due to going to an 87 setup. See the thread, "Oh the Horror" in the Hot Air section. Motor is fine except for the crank and turbo. Everything is located at zip 40037.
Where are you located, what are the specs on the block? the stamped part number on it?how many miles were on it?
Located at Ft Knox, KY
Hot Air block, 117K. Standard bore as far as I know, but I thought it was bone stock. It had been rebuilt at some point or another. Found date stamps on clevite bearings of 10/88. Cylinders are smooth as silk, with zero scuffs, scratches or gouges.
Can get the block # if you would like.
Yes-and are there any stampings on the top of the pistons showing what the block was bored out to? .010, .020,.030?
Stamping on the pistons was STD.
Didn't even think of it, thanks. The number off of the block is 25524140.
3.8
GM 17 stamped on the side as well.
How much for just the block shipped to 10312 or 18346? whatever one is cheapest.
Crank
Also have a NA crank STD/STD could use a polish as well, 75 plus shipping.
