Parts for Sale or trade...........prefer to trade for small things!
jdpolzin
OK guys, I need a few things and I would prefer to trade small things for small things if anyone is interested. Here's a list of thing I have for sale or trade:
1. Black trim: One set of headlight bezels
One drivers rear tailight (mint, complete)
Drivers A pillar
Passenger and Drivers drip rail
Rear window (right side riser)
One Set of Wiper Arms
Passenger Door Handle
2. Chrome trim : One Set of Wiper Arms
Front Window Risers (both sides)
Set of door locks with Keys
3. Stock Turbo Crank STD/STD but will need to go 10/10
4. Stock Heads (64K miles, stock springs still)
5. Front Air Dam (drivers side)
6. 4 spd shifter assy (needs new or HD j-rod)
7. K+N style filter 3.5" opening
8. Fuel Hanger + pump (bought this a while back and never used it, hanger looks like a Spectre and pump is and aftermarket (unsure of brand, serial# is scratched off like Red's XP) Nice Piece here
9. Fuel Hanger with no pump
10. Stock Up Pipe
11. Tensioner Pulleys (2)
12. Stock wastegate actuators (non adjustable (2))
13. TV Cable (Hot Air)
14. Trans DipStick (one Hot Air, one 86-87)
15. Power Steering Parts: One pump, one pulley, some PS lines
16. Crank Sensor and bracket (Hot Air)
17. 86-87 Hard Vacuum Lines (front set (2))
18. Chrome Bumperrettes (4 front, one rear)
19. Drivers Remote Mirror
20. Negative battery cable
21. 86-87 Throttle Body, almost complete with sensors (needs different throtte cable bracket though)
22. Map Light w/harness (needs white wire fixed)
23. IC Brackets (2 drivers, 2 passenger)
24. Taillight Harness (86-87)
25. Body harness (fuse block to taillight)
26. Vapor canaster with sensor
27. Stock Air box (lower half only) also 2 mounts
28. Oil Dipstick Tubes (2 87's)
29. Engine oil dipstick (87)
30. HVAC box top vent piece
31. Antenna Wiring harness (power)
32. Two Power Antennas, need fix kit installed
33. Fuel Rail (86-87)
34. EGR Covers (black and chrome ones!)
35. T Top metal trim retainers (both sides, L shaped pieces that go under the glass
36. Brake Pedal (powermaster)
37. 87 T wheels with new tires (VERY NICE)
38. Rear Bumper Gaurds (2)
39. Aluminum Bumper Support (rear)
40. Rear Trunk Fillers (between rear glass and trunk lid, one for hardtop, one for vynal)
41. Sail Panel Carpet inserts (set, Grey T Type)
Things I need and would like to trade for:
1. Belt Tensioner
2. Y bracket for the back of the alternator
3. L bracket for back of AC compressor
4. Coolant hardlines for heater
5. Power Steering Reseviour and bracket
6. stock Upper Plenum
7. Coil pack and ignition module
8. Sail panel carpet insert for 87 GN (drivers side, nice one)
I have a good working coil pack off my 87. You can have it if you want to cover the shipping. Just taking up space here. Dave
i have everything you need...i can make you a package deal? not sure what everything cost since ive never sold those little misc pieces... but make me an offer or offer me a good trade? pm me
I also have very nice drivers side valve covers that i bead blasted and coated in an aluminum finish. I believe i have 3 of them. -----Jeremy
Jeremy I have both NICE sail panel carpet inserts.
I'll bring them to the next TFW bash.
We can hash it out from there. Also think I have more coil/modules than I need but they are untested in a turbo car. Both worked on NA cars that went to scrap though... Surprised YOU don't have a stack of spares. :)
I'll take the a pillar.....so long as it has the 3 holes for mounting gauges in it.....;)
How clean is #22? Is this the limited style with the two map lights in it?
The map light is in pretty nice shape. The white wire seems to always go bad on these and this particular map light needs the white wire fixed as well. This does have the two lights on it. ----Jeremy
interested in 15 power steering pump ? is it for 86-87 car thanks let me know shipping 08096
I have another interested person on the pump, I'll get back with you if I dont hear from him tomorrow. THanks ----Jeremy
Hey Polzin do you have an alternator or 2 laying around? Both of mine have broken cases.
I will take this. How much ?
Here's a pic of the air dam. It's in good shape. There is only the typical rubbing on the bottom. I would say for a used lower air dam, this one is an 8 out of 10.
