bdasv6
- Jan 4, 2009
3 inch stock style down pipe $100 shipped
Stage 2 intake on center carb intake nice $160 shipped
2 Stock intakes $150 each shipped
86-87 engine harness $150 shipped
Comp cams, Billet solid roller 244/244 $275 shipped
2 Stock inner cooler nice $80 shipped each
42 pound injectors and chip low miles $125 shipped
20 over pistons w stock rods $125 shipped
A C deletes $25 shipped
109 block with main caps and girdle 40 over pistons w shot ping rods and 20/10 crank balanced assembly fly wheel and balancer needs cam bearing in block are bad need over sized cam bearing $800 pus shipping
109 assembled w flat tapped cam standard crank high volume oil pump 8445 heads w valve job and pressure tested installed new springs sock intake stock cam 8445 heads fresh valve job big valves pressure tested new springs ready to install great stock replacement $170.00 plus shipping
2 ECM $50 each
3 stock up pipe one has alky hole $30 shipped each
Stock crank need to be cut $100 shipped
2 stock dash $40 shipped each
Very nice console $275 shipped
Hot air parts turbo heads intake complete harness ECM and few more things but will give all I have for it $350
ESP CNC ported irons $650 shipped
Fly wheel $35 shipped
70 mm turbo hot and cold side jet hot coated 400 miles $1,000.00 shipped
Kenny bell roller rockers one shaft bad for steal heads $165, $200 shipped
70 mm tb and plenum 400 miles $375 shipped
Atr stales headers jet coated really nice 400 miles $750 shipped
Sheet metal hogan intake production style heads 1,200.00 shipped
3 inch external gate dp w jet coated w atr waste gate o2 bung 400 miles $550 shipped
will add more as this stuff goes. Give me time to reply and send pics shipping is for us all others. I can get quote add 3% for pay pal, thanks for a few parts myself just let me know what you have.
see who wants what
2 ECM $50 each
see who wants what
