Parts turbos/ oil pan/ intake manifolds look!
chopped39
Stock untouched 87 lower intake $125
edelbrock 4 barrel intake $100
Box of new flat tappet lifters. dont know brand $15
stock turbo has elbow no wastegate this is a core has shaft play $100
stock turbo has elbow has wastegate boost control solenoid $125 shaft play /core has drain tube also
right sideview mirror blue non adjustable $15
Crane computer system eps Untested $150 for monti carlo
Hooker 2 1/2 down pipe with delta gate $180
f-body t-tops locking nc $200 will not ship 3 gbody ttops 1 locking 2 non locking no interior trim $150 for all will not ship ads super chip for a 1991 gta or irock 350 automatic This must be speed density I installed it in a massair car and it would not even start. It was unopened when I got it $100
Headliner for t-top car its been recovered good driver not a show peice $35
gn 20 bolt oil pan gc $75
Tpi intake with 30 lb injectors $200
Stock intercooler gc couple of fins are bent but not bad, someone painted it $100
Stock tta intercooler with a fan on it pretty rough has some dents $125
Side window trim $50
Stock upper plenum.$25
Stock timing cover $50 some button wear, has water pump and oil filter housing
Stock floor shifter $20 no handle
Rear lower trim panels $25 each little rough no seatbelt or material
Rear upper trim from t-top car has holes for dome lights $25 each gc
Some t-top trim parts. interior parts and outside trim parts email me
Ecm cover and kick panel $20
Trim part under steering column has vent in it gray has alarm led installed in it.$20
Moroso front drag springs and all four comp eng shocks $180
92 grand am rear springs and shocls and mounts new $40
All parts are plus shipping. If prices are off make me an offer. Prefer Paypal
Email me if you want pics hypo-6@juno.com
I will post more when I get to the other side of the basement:eek:
Box of new flat tappet lifters. dont know brand $15 LIFTERS ARE GONE
ttt
ttt
lifters sold to wickedv6
The front springs are moroso 47190 these are from my 70 chevelle . Check summit for details.
I have 6 30 lb injectors 85 plus shipping
I have a set of MSD 50lb injectors that I never used part#2013 and a street performance chip for the 50's 20 degrees at 15psi. $350 plus shipping. I bought these in 1995 and never used them. They are still in the sealed bags
I also have a center console with shifter plate. the plate needs new applique and the crome strip is worn in spots. the cover needs replacing or recovering. $225 + shipping
Still interested if still for sail.I don't no why it didn't go to private message it has been emptied
Found a complete set of gray seatbelts. driver belt is worn pretty good. No hold down bolts $200+ shipping
Found and upper and lower blue door panel set non power missing pull strap and covers. pretty rough I will ship but I would want someone to see these before buying $50 for both.+ shipping
found a front exhaust pipe for a 92 grandam with sohc four cylinder $40 plus shipping.
I also found a lower intake that looks like it was a port job in progress no guarantee came with a parts car$100 + shipping
timing cover sold
intake and plenum sold
