Hey guys, got a question.... I posted this in the general area too, but thought I might have better response here.
Ever since getting my Razors Alky kit hooked up the PCV hose is partially coming off at the vaccum block. It hasn't come totally off, but backs off about 1/2 way, & then leaks a minor amount of oil around the fitting.
Is this something to do with the added PSI?? It's set at 23 PSI now. Should I turn it down to 20 or less for street use, if this is the cause??
Or is there something wrong with the PCV valve itself??
