Performance Parts, Selling my Buick too
jasjamz
THS Racer
PTC 9.5 NL for the 200R4 $700
Seven passes in Norwalk 300 street miles.
CAS V2 FMIC Damaged where tubes go under the core support and tubing drilled for dual alky, and IAT. Asking $450
Powerlogger less than a year old, no instructions or driver disc. Modded ECM
Turbo Tweak Speed Density chip, AEM Wideband,(less than two months old) and 75lb injectors $600
Russ Merrit Iron Heads and Intake manifold
Ported, Big Valves, and Comp springs. Set up for hyd roller. $950
Diamond Pistons, .020 over with Scat forged rods ARP bolt. $600
Precision Turbo 6765 Billet wheel, H cover, ported shroud, Journal Bearing .85 housing. Heavy Duty Wastegate, Mild porting on wastegate hole. Its one week old today! $950
Harlan Sharp 1.55 roller rockers. $350
Hyd. Roller Comp Cam, Lifters, and Pushrods $400
Ported Stock Throttle Body, Doghouse, and Powerplate $150
Add shipping and +3% for paypal to all prices!
Rockets :eek: thats your secret huh.
Good luck with your sale.
Steve
LOL, responding through my phone so please forgive the mistakes. I will have more parts, pics and respond to all pm's this evening.
Reason, the block has a crack. I am not happy to find out, and going to take more time and money than I care to spent on the car at this time. If I'm not going to do it right, I'd rather not do it at all. Sorry guys...
Can you send me some more info on the heads and the cam, lifter and push rods . Like the part# for the cam or what lift etc. Maybe a few pic's if you have these parts of and out of the engine . Send to Gavinxman@yahoo.com. Thanks
Sorry Guys. Stuffs no longer for sale. I will just fix it.:cool: Selling parts and a rolller just does no total out well. Didn't mean to waste anyones time but its too much to loose on my end. Thanks for the offers!
Most of us would rather keep you here and in a TB.....:biggrin:
GOOD........ hate seeing someone sell one of there projects. You could build 3 "low buck" grenade motors like I have, still running the first motor :D and I am into all 3 motors for under 3500 :cool:
Always good to have a spare in the trunk. ;)
jaz jams turbobuick
u made a great chioce to fix her new u couldnt stay away but also unerstand the time and money part u will be happy with the end result and be smiling street racing and doing burn outs in no time let me know what i can do to help bro;)
That "is" an Idea...
X2 on the above statement.
Where is it cracked? How did you find it?
I had 15psi of oil pressure when I used to have 22-25. Yanked it pulled the pan and then found the center mains in bad shape. I looked real close at where the studs went in and saw a faint crack about 11mm long. Pays to have four eyes...:biggrin:
u made a great choice to fix her knew u couldnt stay away but also understand the time and money part u will be happy with the end result and be smiling street racing and doing burnouts in no time let me know what i can do to help bro;)
Will do!
x2
That go's for me too!! You know I love going to the track on little notice when you call. What would I do man?. I have a stock block if you need one to get going. Just give me a call...
