I agree wish list one is what I would do with the addition of a few things that will make traction and tuning easier. The cams you are looking at are not needed or recommended at this point. I would never tell someone to use a flat tappet instead of a hydraulic roller unless I deeply despise them for some reason. If and when the flat tappet goes bad they send fine metal through the engine and end up causing a complete rebuild.
I think if you continue to read here, use the search function, read old post by respected and knowledgeable members you will have great overall experience with the car. Not to put him on the spot but member Kevin B went from a mid nine second TSM class car back to a simple stock type car and seems to be having a ball. Check him out. TurboBuRick and Dr.Boost are my local problem chasers and Bison, RUQWKNUF (Patrick Rubio) are some been there tried that guys with a lot of post. Grumpy is a mellow guy that can keep you from buying stuff you don't need but can motivate you to work with what you have so far. I have been chasing the numbers laid down by his daughter for 3 going on 4 years. Stop laughing, I'm not the only one!![]()
Your mechanic choice is not to hard. They should be great parts changers and neat workers. You do the tuning and road testing. We need to come up with a 25 question quiz on this board to see if they qualify to touch the car. I have seen some hacks and some that could amaze you, but those are far and few.
My mechanics are great, a father and his two sons, they answer all my dumb questions with patience and are straight shooters. Perhaps I'm trying to fix something that isn't "broken", I just look at everybody's mods and upgrades and wonder if I'm missing out on something
When I purchased the car it came safetied but still decided to take it to my mechanics and let them give it an extensive "once over". The car got "two thumbs up" and a few smiles when they talked about their test drive. One of the mechanics said it was the fastest car he's ever driven and would undoubtedly blow his dads Vette off the road.
I think my first move is going to be a change from the Red Armstong 94 octane chip to a TT 94 Street chip and a Scanmaster. I need to learn how the car fuctions before I start talking about cams and rollers. I have been reading Vortex Buicks over and over just to gain some knowledge and I'm starting to get a very basic understanding.
Turbo Nasty: I appreciate all the suggestions, especially the fuel pressure gauge. If I don't mount it on the rail as you suggest is there a preferred spot to mount it?? I dont think I want to bother with a hood mount or an interior mount. I already have an aftermarket boost gauge mounted on the A pillar and I think a knock gauge along with the Scanmaster is my best bet.
Thanks again fellas, I appreciate everyones time and suggestions.
