The Big Honda is TURBOCHARGED!
2009 Honda AquaTrax® F-15X
With its turbocharged 1470cc engine plus a hull engineered for a superior ride, better feel on the water and great splash protection, the AquaTrax® F-15X serves as the perfect choice for on-the-water fun.
Unique Features
    * Multifunction meter indicates approximate remaining ride time in minutes.
    * Honda Ignition Control System (ICS) protects the engine from abnormal operating conditions but can allow the rider to operate the PWC in reduced power mode.
    * Gear-driven dual engine-balancer system virtually eliminates high-frequency engine vibration.
    * Crankcase breather system featuring three breather chambers prevents oil loss or breather-system clogging if the PWC is accidentally overturned.
    * AquaTrax hull design provides excellent overall stability and exceptional low- and high-speed turning performance without sacrificing low-speed maneuverability.
Engine/Drivetrain
    * Lightweight, liquid-cooled, DOHC, 16-valve, 1470cc, fuel-injected, 200-bhp, turbocharged, dry-sump, four-cylinder engine features a one-piece upper-crankcase/cylinder block engineered to withstand the rigors of marine duty. The low-emissions four-stroke design consumes less fuel than a comparable two-stroke engine and meets CARB three-star and EPA emissions standards.
    * Exceptional high performance is provided by a water-cooled IHI turbocharger with water-cooled intercooler. The AquaTrax turbocharger produces a maximum boost of 10 psi to generate more power than a normally aspirated engine. The turbine bearing is an enclosed, ceramic-ball design that withstands sustained high-rpm compressor operation while providing nearly vibration- and friction-free performance. Water cooling of the turbocharger housing maintains optimum turbine operating efficiency, while the water-cooled intercooler ensures a denser intake charge to provide maximum power and combustion efficiency. An Electronic Control Module (ECM) monitors atmospheric pressure, boost pressure, engine speed, oil and water temperature, intake air temperature and an engine knock sensor to manage an electronic wastegate valve that controls turbocharger boost, protecting vital engine components and maintaining long engine life.
