Earlbrown and robzombie you need to check your facts a little instead of coming off as fools...
The 231 is VERY similar in swept cylinder volume when compared to an Olds 307 versus a Buick 350
Olds 307: 3.80 bore 3.385 stroke.
Buick LC2 231: 3.80 bore 3.4 stroke.
Buick 350: 3.80 bore 3.85 stroke.
Now you see that the stroke is 0.015" shorter on an Olds which is about the thickness of a business card so my argument on a 231 being compared to an Olds 307 minus 2 cylinders is accurate.
And given that air volume, CR and HP goals have much to do with turbo selection I am hoping for some input on the subject given the fact that very little run turbos in the Oldsmobile world.
I have acquired information from some in that arena already but figured I would gain some input from those that deal with Turbos combined with FI given the fact that Olds doesn't have many options for FI and many are running blow through setups.
But it seems that I've touched a very sore subject with some... and I am not going to go to some JAP site to get information on a GM vehicle... nor am I going to go to a Chevy site where the inter workings are much different.
Wow, now that's rich, show's your ignorance right there... both Chevy and Oldsmobile have the distributor in the back, but what does the location of the distributor have to do with anything?
And NO, Chevy's almost have nothing in common with Oldsmobiles:
Chevy 350: 4.0 Bore 3.48 stroke
Olds 350: 4.057 Bore 3.385 stroke
Also, the intake and exhaust port setup is completely different on a Chevy, Olds/Buick/Pontiac are similar
Olds/Buick/Pontiac timing order (CCW), Chevy (CW)
I can go on...
You were hating on me from the get go instead of providing constructive input, just because you try and "make up for it" by saying in your post that you are not doesn't mean anything.
It's called being passive aggressive, look it up with your MIT brain instead of being a troll.
I already have the information I need on the subject being from an Oldsmobile standpoint:
http://realoldspower.prophpbb.com/topic260.html
I am asking here to get more detail on the subject since not many people run turbos let alone with FI on Oldsmobiles and want a second opinion from those that have more experience.
Let's stay on topic.
Thanks Bison.
I am trying to keep the car streetable and not have to put in a cage.
