Pics LS GN W/AC TURBO Passenger Side
getteup87
Harrison blower/heater deleted but using kwik AC bracket w/compressor. Have not seen this set up anywhere w/turbo. Anybody have link? I will be doing this w/3 stage dry sump as well. Would like to see some plumbing ideas.
John Harrison will make this possible
I have the best man in houston on this project
Pics will follow
Specialty Metal Craft #1 w/me
This shop is the best hands down
Keep up the good work
kwik ac will be deleted impossible or would look like ____
driven87 setup will look fimilar
but i will do with march pro trac ac/high and inside head valve cover area up and foward stainless works headers 3 stage aviaid oiling low compresser area
still praying this will work
waiting on parts will post pics as promised thanks for reply kevin
we are rolling now
march system will work with aviaid and stock gear box
turbos next!!
Same shop i'm in
working on texas mile camaro
little cage upgrade
i beleive their goal this time 300 mph
little more progress
far from done
down pipe next
We are finally moving again. Pulling for paint and modify frame for Aviaid. 4l80e w/yank going back in.Will have full size k & n right below headlights.
Cage and firewall touched up.Turbo support bracket next then
Turbo, headers,crossover,downpipe off to Polydyn for coating.
WORKING ON FIBERGLASS INNER FENDER WELL TO PROTECT DOWN PIPE, TURBO AND WASTEGATE
HAD TO CUT MORE THAN 2/3 OFF OF STOCK ONE
PLUMBING AVIAID NEXT
Just got car running will install a/c and heat when rest of bugs worked out. It will be trunk mounted. Fast XFI,XIM and trans controller all in glove box area. Will post final pics as soon as engine bay parts show up and I can finish. New Painless wiring harness and Fast wiring still touching up.
that is a boat load of work you've done there and props for such a clean install. who's a/c evaporator r u using in the trunk and how complicated does that get? I'm getting ready to do a 6.0 TT setup in mine and want to retain the a/c... and keep it as clean as yours. yours gives me inspiration
