Looks nice.
If you look at the first pic, you notice that that adapter is concentric to the compressor outlet.
While it fits on the manifold, the exhaust /up-pipe will most likely need to be adjusted.
Here is why I say that.
The stock HA and IC compressor housing have different diameters.
The concetric alignment of the larger IC housing, moves the turbo centerline.
Yes, it shout fit, but it would angle the TB in relation to the original angle, after evrything is bolted together.
To keep the alignment of the TB square to the motor centerline, the turbo centerline needs to move forward.
This of course, creates stress (pushing it fwd) on up-pipe/PS header, which crack by themselves anyway.
Now, if you angle the TB as "bolt everything in place", the face of the up-pipe connection would be angled. (Not sure how much it would be, since I never tried this upgrade)
That too creates problems and leaks.
Just wanted to share my thinking on the keyboard.
All in all, NCE WORK!
If you look closely at the picture, you will notice that the adapter is offset on the compressor outlet to compensate for the larger housing.
Oh yeah ...........
Since the TA49 and TA33 have the same wheels, with the only difference being the slightly larger turbine housing, I am not sure how much benefit a TA49 will give for the work required at boost levels 20 and below.
I would LOVE to see back to back comparison testing.
