Like Regal-Nut says, there's a number on the back face of the wheel. That is the mold# it was pulled from, and the #4's seem to be the most concentric of all of them. Our rules state that only the casting nub(on the tread surface) may be lightly sanded so you want the truest possible wheel as we can't modifly them SUPPOSEDLY! But I've found that by chucking them in my cordless drill and turning them over hand held sandpaper, you not only get the nub but dish out the center of the wheel slightly which also reduces friction points while helping to maintain a steady tracking wheel. Of course the sanding scratches have to be polished out too then! You'll feel how outa round the wheels are when you're sanding them like that too. Reducing friction is more important than reducing drag since they never get up to speeds where the forces of aero really come into serious consideration. Check out my "King" superbird, not particularly aerodynamic compared to a wedge. I even tried to handicap it with the steep w-shld and the nose smile brings it down to the 3/8" min height, making it slow offa the peg. But it smoked several wedges that dad's had made to come for my blood anyways! I put the lead as high up in the back as possible cuz we have a 50-50 track and it's the best compromise. The engineering behind that is that nose wt. brings you dn the hill, tail wt across the flat. By high mounting the wt., the center of gravity moves forward when the car is on the incline and shifts rearward on the flat w/o moving and causing wobble. You can establish where you should have your weight per what kind of track you're running on. Rear wt behind a tailight can be added or subtracted to bring it into weigh-in spec. and helps offset for the lifted wheel on opposite side front. By running the cars on an incline that's level side-to-side I make sure they track straight first and even weigh dn the nose to use both fronts and adjust them in case the lifted one ever touches. I've never used one of the metal axle alignment jigs avail on the net. Also, say your car pulls to the right. That could be as much fixed or a cause of left side wheels needing to be bent back as bending the right side whls forward. Make sure you're aligning the proper location. Several times down your incline while watching the wheel's position on the axles will show which one is pushing in or pulling out to the end of the nail.
"Pinning it down" is that I'll be using shortened straight pins to secure the upper and lower parts of my car as "No moving or loose parts" is in our rules. I can pull them out later to display it opened up then!
This year my body is cut from a single piece of 2x4. 2-5/8" wd.(cannot max out @ over 2-3/4" finished and painted) I cut the middle out 1-13/16"wd on the table saw and will Dremel it to as thin as possible. It fits over the 1-3/4"wd. scout block that will begin to become my chassis. Previously, as in last year's const. pics I've used 1/2" wd side blocks like the other guys have mentioned too, and pinned them to the main body with cut coathanger pieces for pre-glue alingment. Like was said, trace the cut out center section onto the side pieces then cut them idividually, mount em, then fine tune for fitment! Be sure you've Dremelled out enough wheel room before you get the epoxy out.
Lookin forward to enthusiastically talking with you guys more, but agreed that I wouldn't touch my car any more till Feb. Our derby isn't till end of April, boys haven't got their cars yet and it's not really fair to others to have 4months to perfect mine. So it'll be a while before I show progress pics.
