I was over at the machine shop today and my machinist was showing me some import engines he was working on (I believe they were DSM 4 bangers).
Their piston oil squirters caught my eye. Talked to the machinist about doing it on a 109 and he had a really interesting idea on how we could add that.
It involved cutting a small channel outward from the main bearing bore oil holes and then angle drilling a hole aimed at the backside of each piston. He then talked about adding squirters with check valves so they would not bleed off oil pressure below whatever the check valve spring was set at (to maintain idle and light cruise pressure) but when the pressure came up they would open up and shoot the piston backsides.
I thought this was a really good idea but the only potential problem is that the main webs may or may not be weakened by such an operation. Also, not sure if the oil system would be up to the task of delivering the volume, and last but not least, potential hp losses due to increased windage.
Has anyone dabbled in any kind of piston oiling setup?
