Originally posted by Nick Micale
Originally posted by Mac in SD
Dave, if by "proud" you mean that the sleeves are above the deck by .002-.003, then hold on. I'm pretty sure that the TA blocks have the sleeves up a little, and that it's supposed to be that way for head sealing and integrity issues. Could be that that alum block you have is set up the same way. ... /QUOTE]
I know this is a "piston" thread Dave, but just wanted to add a comment about the liners. They do stick above the deck on the TA block and need to be seated prior to decking the block.
Since the surface to be machined is alum and steel, a normal surface cutter cannot be used. I forget the name of the machine needed, but make sure whoever does the work on your block is familiar with machining/building alum motors
Once I find my way to civilization, that shouldn't pose too much of a problem. There's a LOT of aluminum motors out there now days. With a little research, a LOT more than I had suspected!! There's people making LS1 alum. blocks, and of course most of the high end european cars run ALL alum blocks. Some sleeved, most not.
So finding a good machinist should be do'able.
Assuming of course I even decide to build that block. I may just build the all aluminum one. I can get a LOT more C.I. out of it.
