xrunner123
- Oct 2, 2002
Can someone review these powerlogger files? I'm going to give up....
I have knock on the instant of boost with the first gear being the worst. I assume this is false? I had fueling issues which I've resolved and I recently added Alky so I can run more boost but now I get knock. It was fine at 16-17lbs but I guess more power is doing it??? I'm at around 20lbs now.
Downpipe is not banging and I have HR motor mounts. I've replaced the knock sensor and made sure it's not torqued down tight. What else can cause such bad knock?
I'm logging PLX wideband and fuel pressure on analog 4
Thanks so much.
Thanks so much.
