Hey guys I just got my GN out of storage after 15 years. Ive been out of the loop for a long time and want to get my car going again. Anyways my front main seal rotted out and leaking oil so I took the front cover off and decided to check the 2 dots that line up the cam and crank shaft. its a 206/206 roller from Weber and I advanced it 2 degrees back then with the multi key ports. I cant remember how I did it with the timing set I have. Nothing is labeled on the sprocket. I added 2 pics for you guys to see. one of them has 2 dots on the crank shaft sprocket. Which dot is the correct one so I can line it up correctly? Also I found it strange that the 2 dots never line up when I keep turning the crank. I'm worried I installed it wrong but It ran great and idled smooth. is it because when I advanced it 2 degrees with the multi port slots the dots don't line up anymore?
George
George
