JDSfastGN
- Jun 16, 2001
Well after finding a check ball out of place I put the tranny back together and it worked great. Last night I decided to put some miles on it and after about 10 miles of driving, it began to have the same symtoms as my last post (see further down the tranny section) It starts out in 2nd gear, and I found out I do have a 2-3 shift but it is extremely high, at about 65 mph. It is extremely hard when it shifts. and from a start if I drop it into 1st manually and kick it back into drive the 1-2 shift is extemly late and harsh as well. When we had the valve body off, the TV system appeared to be operating alright but the symptoms sound like the TV vavle is messed up and causing too high of pressure and the governor can not exhaust all the pressure before it can drop back into 1st gear. Also adjusting the TV cable has no effect on the shift points or the harshness of them, it still does the same thing. Before when the tranny was working fine the TV cable was able to be adjusted. What should I be looking at and what other shift valves should I look at when the valve body is down. This is the same valve body and Art carr shift kit I have always used and after recently destroying the stock OD planetary and twisting the input shaft, I guess some debree some how is hanging up something.
