Originally posted by turbo buicks
HOW YOU LIKE YOUR F-BODY RADIATOR???
ME LIKEY RADIATOR!!
So far so good, actually havent driven much over the last few days, but the couple times I did there has to be about a 10 degree drop. Just going by the VDO gauge right now as my brother swiped the Scanmaster back that I was borrowing and I dont care to ride around with TLink all the time. If I race tommorow night, or the next, I should be able to really see what its doing with TLink. Noticed that the dual fans dont seem to be running as much as before which is a good thing since they draw so much power.
Hold up, come to think of it, I did drive for about half an hour the other night with TLink hooked up. Dont know what the temp was outside. As hot as it has been around here, even if it cooled off it still had to be in the mid 80's. Coolant temp stayed in the 160's. Dipped to 159 a couple times. Hit the car up a couple times back to back and the highest temp I saw was 168, and then dropped down. I think I saw 162-163 the majority of the time. I still need to get some exact readings during the daytime with the sun out, but again looking at the gauge, it seems to stay around the same during the day as what I saw the other night.
Pretty cool when you can have the engine running for awhile and put your hand on the radiator, hold it there, and it doesnt burn ya
P.S. Install was a breeze too. Nothing out of the ordinary. Only had to modify the RC fans a bit more (grind down sides just enough to fit between end tanks which sit just slightly closer).
