turbonut85
Rarely used member
- Apr 11, 2008
if the 5/16" vent line from the tank to the charcoal canister is plugged solid...what driveability issues would this cause??
SignUp Now!You bet.A vented gas cap w/ the fill neck pointing to the rear of the car??
more than likely it's plugged at the fuel header. the stock vent is orificed and that's a really small hole. its located inside the vent tube where the tube passes through the header.Been chasing low BLM, rich idle, and KNR during spool up....(comes on around 12-15 psi, then drops off right away as the 2nd pump comes on...also been having issues adjusting fuel pressure...so I blew out the return line, and that's when I checked the vapor line...plugged solid...can't even blow through it with a 180psi air compressor...
also called the fuel pump hangerDefine fuel header...??
