Plugs
mike lee
Looking for opions on spark plugs with the coooler weather coming going to the track my combo is 109 block 40 over stock cam minor head porting TE-60 limit dual fuel pumps second pump on at 10# of boost 2004r with all the good stuff 3200 stall with manual lock up 22# with 110 cam 2 old Eastern front mount Rjc power plate pulleys boost controler Houston down pipe int gate 50# injectors with caspers thumbwheel chip 26degrees of timing stock mass air flow 275/60/15 nitto dot slicks!!!! Using E3s now any thoughts best run to date 11-90@116 @Etown last fall Thanks Mike:biggrin:
