To hit on maint and service the PM again.
A simple test that will tell you if its working right or condition its in.
Pop the hood
IGN sw off pump the brake pedal until its hard ( about 10 times or maybe more)
Turn the ign sw to "run" no start/crank position
PM will/should energize, The brake fluid level in the reservoir closest to the engine should be pulled down to around a 1/4" in no longer than 10 seconds.
If this does not happen then something is not right pump or internals or something.
I wrench on GN's frequently that the owner feel as though the PM's are working fine when driving around and they FAIL this test and then I bring it to the owners attention and they say why its working fine, I am not getting a brake light and its stops as good as ever.
Then the next thing I know their brakes go out w/o warning or they get a brake light, motor wont shut off, etc.
Sure the PM could go out even if they pass the above test its a mechanical man made part.
I have had vac brake MC's go to the floor in traffic
and would not pump up with out a sign of leakage on the firewall .......they all can fail!
Keep and eye on it and learn how the system works. Main reason most swap is for money it takes on parts and service for the PM.
Not say that switches wont go out, accum go bad, and other parts.
All in all i believe if more folks had a better understanding of what to check and how it works then it would probably save some heartache...but not money.
The PM is an expensive sucker
My 02
