TurboMonte 2
Car Nut
- Mar 21, 2006
X8/whatever for coil pak (&/or plugs, plug wires). How's about it Scot502--WHAT have you done yet re: another coil-pak/ICM testing--before we all go
SignUp Now!X8/whatever for coil pak (&/or plugs, plug wires). How's about it Scot502--WHAT have you done yet re: another coil-pak/ICM testing--before we all go
Also not really related but???? Get a modern custom burned chip from Eric at Turbo Tweak. That outdated generic one you have is marginal at best.
I've had the wrong range plugs cause this, and also had the coil pack cause this.
What plugs you running?
Have you run an ohm meter across your coil pack towers?
Bad plug wires could also cause it...ohm those out too.
How much boost?
waiting on new boost gauge but wategate is 1 turn in from stock
how can i put car mods in lower left corner like everybody has
r43ts at 32 gap,taylor thundervolt 50ohm per foot, new gm coil pack ohm out good. pop is gone but it surges at wot now not bad but you can feel it checked all vacum lines new intercooler hoses.im runnig race 93 and 100 pump gas![]()
After you get the boost gauge and start adding boost, you'll need to close the gap on the plugs a bit.
You should also monitor your fuel pressure at boost and WOT to see that you're getting proper fuel pressure.
....and defintiely get a chip from Turbotweak and some alky (Razor's kit is great) if you don't aready have it.
ordered turbo tweek chip i hope it is all you guys say it is mybee ill have money for razors alky set up soon.:smile:
New turbo tweek chip is great no knock running 18 on boost how much should i go. I run 93 or better gas.:biggrin:
