poping @ high boost rpm?
2QUICK2B6
Black Car Fever
This problem is happening on my dads 13k mile GN. We change the coil pac an moduel same thing .. cam sensor ?
new wires an plugs .. not sure on valve springs . car has set for 1 yr
.28 gap 27 psi 116 octane .. single walbro fp precison stock location intercoler .. DR' 255 60 i think 16 inch wheels
Weak motor mount? Header shorting power wire from battery to starter from torque under boost?
im thinking cam sensor car is tight ... polly bushings ... first an only track time 11.80's with a te44
Is it pretty consistent with rpm? Does it get worse the harder you push? If so I would pull the valve covers and check rocker travel. Could have a possible worn cam lobe. :(
RL
yes only does it over 75mph highboost ..... He dint tell me the boost gauge isnt working ..... might be a vac hose off ....spent better part of yesterday puting on gbody front bumper fillers.... uh
sounds like a popping noise an cuts back... car has aftermarket springs .. precision front mount kenneybell cold air intake . p61s turbo ... 60# inj and erics race chip running 116 octane .. pts 9x11 converter lock up
Interested to see what this turns out to be....Had similiar issues last trip at the track popping and would nose over then clear out and then repeat...Had a puff of white smoke that showed up on the video of my last pass thinking mine might be a blown head gasket although nothing showed up in the oil or coolant and no raise in temps...
my car smoked white smoke for over 4 yrs ... no oil in coolant but kept having to add antifreeze .. then it gave up the ghost... im sure my heads were lifting on top end an water going out the exhaust
Ya that's what i think is happening heads lifting....Like your dad's mine only shows up at the top of the track usually around 100mph or so......
this is the car with issues cant tell in pic but its an astrroof
