Since i already have alot of coils and modules on hand, send your parts to and from and i will check them for free. My zip code is 66212 if you want to check shipping charges online.
/QUOTE]
Thanks for the offer Bryan, I might do that
SignUp Now!Since i already have alot of coils and modules on hand, send your parts to and from and i will check them for free. My zip code is 66212 if you want to check shipping charges online.
/QUOTE]
I see you dont have a air filter, but i cant really see the coil pack.
No wires were cut? Ive never put the series II on my car or any car, really had no problems with maf sensors or modules. Plugs right in and runs? Maybe i missed a few years... wouldnt suprise me one bit if i was wrong.
BW
To Mike70 GTX and all the others who said something like "me too"...
I have also been trying to sort out a popping/misfire under boost for more than three years now! I have replaced ALL of the ignition and fuel system components, sensors, etc and no improvement. My good friend and turbo Buick mechanic has spent numerous hours checking wire harnesses, grounds, etc. Earlier this year he did identify one problem with the car that was also causing a misfire. Apparently, the electric fans were causing some kind of interference with the spark control feature of the Translator Plus. Everytime the fans would come on or shut off, the engine would stumble and if you had the AC on and changed the blower speed, this would also cause the engine to stumble - weird. We bypassed the spark control on the Translator Plus and that eliminated the stumbling related to the cooling fans and AC blower, but the misfire under boost is unchanged. I'll go back and re-examine why the fans are affecting the Translator *after* I get rid of the popping under boost which is a much bigger problem.
Right now, the car runs perfectly except when the misfire shows up which is only intermittantly. Just yesterday I finally ordered a Power Logger which I *HOPE* will show me what is actually happening when the misfire occurs.
I hope everyone else's popping/misfire turns out to be a simple fix, like a coilpack, but that certainly has not been the case with my car.
Rob
I unplugged my cam sensor and went for a test run and the problem seems to be fixed. I stopped by my local auto parts place and a new sensor was $400.Is that correct?
If your sensor needed to be replaced, the car would be dead and not running.
BW
